hi,
I have two different boilers, namely B 6203 and B 1104. B 6203 is a dual burner system, can use fuel oil or natural gas, while B 1104 is can only fuel oil. Fuel oil used on those two boilers is the same, a marine fuel oil (MFO) with viscocity 15,21 cst (on 100 degree Celcius).
When used MFO as fuel, those two boilers have a different SO2 emission. B 6203 emission is 2000 mg/NM3 while B 1104 emission is only 100 mg/NM3. We use fuel oil treatment (FOT) that it's active content is Mg. Mg content on MFO is about the same, 38 ppm.
The conditions that differ those two boilers are :
1. emission laboratory analysis. B 1104 used spectrofotometry as analysis methode while B 6203 used Iodometry (titration with Iod). I have checked emission of B 6203 with those two different analysis and got 2008 mg/NM3 with Spectrofotometry and 2222 mg/NM3 with Iodometry, still high emission.
2. MFO temperature inlet burner. B 1104 MFO temperature inlet burner is 90 degree Celcius, while B 6203 is 60 C.
My questions are:
1. Parameter that affect the SO2 emission? why while we used the same fuel oil, the SO2 emission on those two boiler is greatly different.
2. Are viscocity of fuel and gun burner type affect SO2 emission?
3. Is point injection of FOT is affect the SO2 emission too?
As an info:
1.when we used natural gas as fuel for B 6203, the emission is low, less than 100 mg/NM3. Sulfur content on fuel oil is 1.7%weight and sulfur content on natural gas is only 3 ppm.
2. Oxygen excess on those two boilers is maintained at 2-4% excess.
thanks,
dj
My questions are:
As an info:
thanks,
dj
