High Pressure Tubing: Where to find supplier 1
LJDCRF
Automotive
I am trying to make a tubing assembly for a dual fuel pump system my company sells. The working pressure of the system is 28,000 psi. The factory high pressure fuel lines are 8mm OD and 3mm ID. They are made of a steel alloy. I am trying to find a tubing supplier or someone who will build the assemblies off my drawing.
What material would give me the pressure capacity I am looking for?
Who could supply this tubing?
I have contacted USUI which is the supplier for Cummins and GM. They are have not commited to working with us because of our low quanity.
Swagelok, perhaps?
image.php
Sometimes I only open my mouth to swap feet...
Thank you rootem. Mark Jean was very helpful and led me to a good source.
Hello my friend
You can send your drgs to rajan@hydrolinkaz.com,
We are distributer of Butech tubes & fittings. We can do your piping work up to 150,000 psi even.
Best Regards
Rajan Bedi
00994502201798
