The stabilizing resistor in high Impedance REF assists in such a way that the derived current in the relay circuit (Rst + Rp) cannot reach the relay setting threshold when the maximum through current saturates a CT with its DC component.
Generally, the faults closer to neutral have less magnitude of fault current while the through current fault would be higher.
So, will the stabilizing resistor allow the magnitude of current for the faults closer to neutral to cause the operation of the relay?
