hide viewport
Zapster
How do you hide the boarder of a view port for printing while keeping the content of the port?
put the viewport border on the layer defpoints
Or you can switch off the layer on which the viewport was created. Do not freeze it or you may get odd things when you hide for plotting.
Thanks for your help.
Place all your viewports on a layer called "defpoints". The defpoints layer DOES NOT PLOT, even though you can still see it in your drawings. This layer was developed just for such purposes. This makes seeing the viewports possible without ever worrying about the frame plotting out.
If you don't have a layer called defpoints, don't make one. Rather, put a dimension on the drawing, then delete the dimension. Layer defpoints will be created for you. You can freeze layer defpoints so you don't see it on the drawing. No harm will come to your drawing.
The defpoints layer was created for the definition points of dimensions, but some users put viewports on this layer. In case you didn't know how not to plot a layer correctly, you would click "do no plot" on that layer in the Layer Properties Manager.
Flores
