Hi Folks,
I need HELP.
We use flexure that is round, 17-7 PH A Stainless Steel and 3 mil thick, 3/8 in dia. weld onto another flat surface
that is 17-4 PH Stainless Steel. The problem here is how can we keep the flexure say 100% flat or close
to 100%. Another information is that we sandblast (micro) onto one side only, after sandblast, I observe
the flexure under microscope and there curve or dome on the opposite that is not sandblast. Our vendor receive
the material from it vendor as Annealed but the material later rolled down to 3 mil from unknown original thickness.
Our vendor then rolled out the material to get it to flat which I did check that after we receive from our vendor
and that they do look flat observing under our interferometer instrument.
Question: How can we keep the flexure flat after sandblast on one side?
Thanks Folks,
BSDME
I need HELP.
Thanks Folks,
BSDME
