We just recently upgraded to Teamcenter 11. Prior to the upgrade when I would do a save as, the majority of the fields would automatically populate with information from the existing file that I was using to save as. This was nice because many times much of the information did not change. Since the upgrade all the fields are empty. Is there a setting I can change to get the fields to populate using info from the existing file? Thank you in advance!
Thank you,
Trent
NX 11.0.1.11
Thank you,
Trent
NX 11.0.1.11
