I think I need to use hlookup and vlookup in the same formula but not sure how to do this. I have attached my file and there are two workbooks. One labeled output (raw data) and the other labeled Loads (data organized from output). If you take a look at the Loads worksheet B2 is the value I would like to obtain from a formula (versus typing each value individually). This value is found if you look under M406 and LC15 in the output worksheet. Could anyone explain or show how to write a formula that will take B1 & A2 from the load worksheet and find the corresponding value in the output worksheet?
