Hi Folks ... I am not a structural engineer thought posting to this site could get me in right direction. Looking to support a deck in Michigan, hired a local structural engineering firm to do the post/beam and footing sizings and although most of work seemed okay, was advised to embed a 6x6 wood post into the bottom of a 36 inch Bigfoot form with a 14 inch Sonotube sleeve over the top.
This seemed to not pass the smell test ... I suspect putting a 6x6 post to the bottom of the form severely weakens the structure. Also, lots of people around here feel embedding posts (even pressure treated) is less robust than posts anchored to footings above grade. I contacted the manufacturer of the Bigfoot form system and they advised against putting the post to the bottom of the form.
Looking thru the calculations of engineer hired for job, vertical load on the footing is 16682 lbs. I found a round footing sizing chart (google) and for 2500 PSF soil conditions a 36 inch footing is needed. My suspicion is this table assumes 2500 psi homogenous concrete footing with centered axial loading (straight vertical load).
I cannot seem to find any info on how to design a bell shaped concrete footing with an embedded wooded post. Is there such a thing? Perhaps a simpler footing design is in order (like a rectangular shape with steel reinforcement). Since this project is for my home and I plan to live here until I die, I would like to construct these footings in a robust manner. I should add footing depth is 42 inches minimum for this area and that the height of the posts above grade will be about 11 feet. Soil has been tested (silty clay) and will withstand 2500 PSF. Deck will attach to structure of house.
Where can I find info on proper design techniques?
