Aug 15, 2007 #1 B Bendek Guest I need help to modify the Shift+Right click snap menu in Autocad 2007 using the command CUIIMPORT, as I want to add few command that I always use.
Aug 16, 2007 Thread starter #2 A Agostino Guest Hi, Run the CUI command, expand the Shortcut Menus node, and modify the Object Snap Cursor Menu. Cheers!
