Autocad 2025 Insert Palette
ohiocad
I've searched quite a bit, and have found multiple comments or web posts that say they should work... none have....
In Autocad 2025, Block Insert Palette.... when you scoll through the available blocks, and hover over one, you get a popup that hides the blocks behind it, making it a true PITA to work through blocks when you're close to the one you want. Is there a way to turn that annoying pop-up off?
I currently have reset "I" to Classicinsert to avoid the headache but that's not really helpful for trying to use a palette with a network/central library.
I realize I'm probably "old school" and hate the new gadgets, but I STILL use the keyboard more than on-screen buttons. The computer isn't that old, but the pause when it switches between enlarged palette pop-ups is more than a little annoying and disruptive. I just want it to work.
