Help in a Journal with Process.Start command
Ehaviv
Computer
IL
Hi
In this journal I get a blank output:
Dim outfile As String = _
"C:\haviv\_00_vita_vme_std\_m3u_assy_002" & "\ugiiOutput.txt"
? can someone help to explain this.
Code:
 'Start an invisible process.
 'You can start a process and get its output without a visible window.
 'This shows how to changes to the System folder,
 'run the DOS Dir "*.exe" command and send the output to the Output.txt file.
 'The Windows XP command shell interpreter recognizes "&&" as a command separator,
 'thus, you can put multiple commands on a single line.
 ' "&&" command separator,
 ' ">>" redirects output into a file, append to existing
 ' ">"  redirects output into a file, clear the existing.
 ' Chr(34) = "
Option Strict Off
Imports System
Imports System.Diagnostics
Imports System.Security
Imports System.Windows.Forms
Module NXJournal
 Sub Main (ByVal args() As String)
    Dim myProcess As Process = New Process()
    Dim s As String
    ' Get the System path.
    'Dim sysFolder As String =
       'System.Environment.GetFolderPath(Environment.SpecialFolder.System)
    Dim ugiiFolder As String = "C:\Program Files\Siemens\NX 8.5\UGII"
    MsgBox(" Changed to folder = " & ugiiFolder)
    ' Createe the command line.
    myProcess.StartInfo.FileName = "cmd.exe"
    myProcess.StartInfo.Arguments = "/C cd " & ugiiFolder & _
        " && ug_clone -pim=Yes -o=clone:Import -Part=C:\_m3u_002\comp1.prt" & _
                                            " > " & Chr(34) & outfile & Chr(34) & " && exit"
    ' Start the process in a hidden window.
    myProcess.StartInfo.WindowStyle = ProcessWindowStyle.Normal  'Hidden
    myProcess.StartInfo.CreateNoWindow = False  'True
    myProcess.Start()
    ' Kill the process if it doesn't finish in one minute.
    myProcess.WaitForExit()
    'myProcess.WaitForExit(1000)
    'If Not myProcess.HasExited Then
        'myProcess.Kill()
    'End If
    ' Show the results.
    MessageBox.Show("The 'ug_clone ' command window was " & _
        "closed at: " & myProcess.ExitTime & "." & System.Environment.NewLine & _
        "Exit Code: " & myProcess.ExitCode)
    myProcess.Close()
 End Sub
End Module
Thank you in advanced
If your intention is to import files to teamcenter, try using the "ugmanager_clone.bat" found in the UGMANAGER folder.
www.nxjournaling.com
Cowski thank you.
My intention is to write a journal that run in native mode.
and manipulate an Assembly as the following:
Save original components parts names in part attribute.
change parts names to comply nxmanager mode, shorten long names
Replace spaces and like so.
and then run ug_clone.exe to import the assembly to nxmanager.
Thank you again.
In that case, definitely run "ugmanager_clone.bat" instead of ug_clone.
I ran your code on a test file and got an error of "need to have TCROOT/IMANROOT defined..." (yes we have TC installed). The "ugmanager_clone.bat" will set those environment variables before handing control over to ug_clone. Alternatively, you can set these variables yourself, before calling ug_clone.
Ahh OK thank you very much.
meanwhile I opened a command prompte window changed directory
To ugii and run this
ug_clone -help > out.txt and this indeed
created a blank out.txt file. ? ?
I'll try it with ugmanager_clone.bat
Thank you again.
