gaber26111
Hi engineers and colleuges here,
Well, i am working on project related electric bikes, in other words i am working on the driving part,and i am alittle bit confused about some stuff.
We already specified a 380 acv , 7.5kw, 10 hp driver motor.
Also decided to use battery bank from chloride manufacturer, there are different values of rated volts and amps, i am thinking of 12v, 200ah battery, and use 3 or 4 of them in parallel or series depend on the design requirements of volts and amps. The power needed.
I am planning to use inverter between the battery bank and the motor,
Other way of design, to use 12dcv to 220acv inverter with the battery bank and then use 220acv to 380acv VFD to drive the motor with the suitable power needed.
What i need help and advise about is, is it possible to use inverter from battery bank to the motor?, in a direct way?, if so please suggest
