RobertHale
My company was called in to look at rehab and renovation on a jail built in 1901. From a historic sign, I know the builder for the jail was the Pauly Jail Building Company. For a large chunk of the building, it is what you would expect from a turn of the 20th century building URM with wood joist framing over a crawlspace. However, for the "lockup" portion of the building, there is a floor framing system that I have not seen before. Essentially, it looks like S8 (or equivalent) beams spaced at roughly 36 inches in an arched corrugated form supported by the beam bottom flanges. In the larger spaces, there are steel beams (S12) that provide intermediate bearing support for the embedded beams. I did my best to use the Wayback machine to look at the information on slideruleera.net, but I didn't see any system that matched what I saw. I am wondering if anyone has run across this system before and might have some information about it. See the pictures below. I will note that some rehab appears to have occurred recently, but no one in the project seems to know what happened and when.
