Hello Guys, I have a trouble her
Kikoupe
FR
Hello Guys,
I have a trouble here... One year ago I posted this topic and it was OK. I've got a code working well but now it's did not work at all.. could you guys help ?
I have a error on the leafproduct method...
Code:
Option Explicit
Sub CATMain()
Dim USel As Selection
Dim USelLB
Dim InputObject(0)
Dim oStatus
Dim i As Integer
Dim sName As String
InputObject(0) = "AnyObject" 'selection filter forces user to select specific objects, AnyObject allows selection of any object
Set USel = CATIA.ActiveDocument.Selection
Set USelLB = USel
MsgBox "Please select fix points." & vbCrLf & "Select a curve only !" & vbCrLf & "Presse escape to cancel the process."
USel.Clear 'clear the selection before making a selection
oStatus = USelLB.SelectElement3(InputObject, "Select objects to list names", True, CATMultiSelTriggWhenUserValidatesSelection, False)
    Dim partDocument1 As Document
    Set partDocument1 = CATIA.ActiveDocument
    Dim part1 As Part
    Set part1 = partDocument1.Part
    Dim hybridBodies1 As HybridBodies
    Set hybridBodies1 = part1.HybridBodies
    Dim hybridBody1 As HybridBody
    Set hybridBody1 = hybridBodies1.Add()
    hybridBody1.Name = "Here the result"
    Dim hybridShapeFactory1 As HybridShapeFactory
    Set hybridShapeFactory1 = part1.HybridShapeFactory
    If (oStatus = "Cancel") Then 'User hit esc on keyboard
       MsgBox "Macro canceled by user"
       Exit Sub
    Else 'Loop through selected objects and list names
i=1
Dim doc: set doc = USel.Item(i).LeafProduct.ReferenceProduct.Parent
Dim meas: set meas = doc.GetWorkbench("SPAWorkbench").GetMeasurable(refObject)
ReDim cog(2)
USel.Item(1).LeafProduct.GetTechnologicalObject("Inertia").GetCOG cog
'ReDim cog(2)
'USel.Item(i).LeafProduct.GetTechnologicalObject("Inertia").GetCOG cog
		For i = 1 To USel.Count
Dim refObject as Reference
set refObject = USel.Item(i).Value
        	sName = USel.Item(i).Value.Name
        	sName = Replace(sName, "Selection_", "")
        	'MsgBox (sName)
        	Dim hybridShapePointCenter1 As HybridShapePointCenter
        	Set hybridShapePointCenter1 = hybridShapeFactory1.AddNewPointCenter(refObject)
        	hybridBody1.AppendHybridShape hybridShapePointCenter1
        	hybridShapePointCenter1.Name = "Point " & i
        	'MsgBox hybridShapePointCenter1.Name
        	part1.InWorkObject = hybridShapePointCenter1
        	part1.Update
       Next
    End If
msgbox "ok"
USel.Clear
End Sub
Well you gave us no error message...
But...
Code:
    ReDim cog(2)
    ReDim cog(2)
[b]set refObject = USel.Item(i)[COLOR=#EF2929].Value[/color][/b]
Notice that variable [tt]i[/tt] is outside the For...Next loop. Therefore the LeafProduct method has an undefined Item value.
ALSO, why Redim and GetCOG TWICE?
ALSO, you never Set an Object to a Value. It's an OBJECT!
Skip,
[glasses]Just traded in my OLD subtlety...
for a NUance![tongue]
LeafProduct will fail (most likely) when active document is a Part, not a Product
Hi guys,
Thaks for the support, I change the code, my mistake i paste the code i was working on but nothing change i have a error on the leafproduct method...
Why it's work on the product and not on the part ?
what is the code to select the part from the edge/curve selection and get the COG ?
Not gonna venture a guess on your "change"
Please post your code.
Skip,
Code:
Dim prd as Product
Dim partDocument1 as PartDocument
If TypeName(CATIA.ActiveDocument) = "PartDocument" then
  Set prd = CATIA.ActiveDocument.Product
Else
  Set prd = CATIA.ActiveDocument.Selection.Item(1).LeafProduct
  Set partDocument1 = prd.ReferenceProduct.Parent
End if
Hello Thanks a lot it's works !!!!
