Hoping someone could help clear up some confusion for me, or point me in the right direction. I'd been under the impression that for a helical gear, the true involute profile would be located in the transverse plane. However when specifying helical gears, pitch and tooth thickness are often given in the normal plane. Additionally I was under the impression helical gears could be cut with standard hobs, that are set angled from the gear axis, to create the helix angle. This would leave me to believe that the true involute form for helical gears is being made in the normal plane--the plane that is perpendicular to the action of the hob. Is someone able to help explain where I'm going wrong here? Should the true involute form be in the normal or transverse plane?
Thanks in advance.
Thanks in advance.
