wsuengineer
- Oct 2, 2006
- 11
Problem: How to heat air from 30ºF to 275ºF in a wind tunnel. Initially the air must be heated then maintained. Heater coil/medium cannot be in windtunnel (test particles would collect on them). Thus air must be first heated then introduced into the wind tunnel.
Specifications:
Volume Air in Wind tunnel = 110 cu. ft.
Volume Air rate = 4000 cfm
Velocity = 2164 fpm
Ideas: Electric duct heater --> 310 kw heater! 380 load amps! Too high of a load.
What are the options?
Specifications:
Velocity = 2164 fpm
