Heat Treatment After Welding A356.0
KirbyWan
Aerospace
Apr 18, 2008
586
Howdy all,
I have a cast aluminum part that is A356.0 which MMPDS-01 indicates is weldable. I'm trying to determine if a post weld stress relief is needed and if so what it should be. This is for a light to moderately stressed aircraft part that is secondary structure (a cast duct). If someone could help with this I would appreciate it, or if you could provide a source of information that explains what does and what does not need post weld stress relief that would be even better. I seem to struggle everytime I need to design a repair for something using a welding process because I don't have a single source to go to for all the small yet critical details that go into a succesful weld.
Thanks,
-Kirby
Kirby Wilkerson
Remember, first define the problem, then solve it.
