I have been for some time trying to muddle my way through some heat transfer calculations. I would like to know if I should be considering convection in my thinking and if pressure would play a role.
My application uses an element on one side of an aluminum platen .625in thick with a surface area of 4856sq in, it is fastened to the platen with a .125in thick alumin sheet and insulated on the sheet side with thermal conductivity of .07 W/mK. I know the aluminum back sheet has a conductivity of 237W/mK, the platen has a conductivity of roughly 205W/mK, and the material between the platens has a conductivity of roughly .14W/mK
The platen/element packages sandwhich the material being heated/cured, pressurized to 100psi and starting at roughly 70F and heating to 300F.
I have done all the calculations for these individually, but am wondering should I be taking into consideration the heat loss due to convection from the side of these element/platen assemblies. Should a pressure of 100lbs/sq in have any factor in my calculations? AND shape... I often use a rhombic shaped platen, and I know it will lose heat differently then a rectangular shape; but I have not been able to find and relatively simple calculations to determine how much more.
Until now I have been using the "standard" numbers and watt densities that have been used for the past 40 years here, they work to a great extent but I would like to understand this a little more then I do now. Any suggestions?
Thanks!
Thanks!
