manarfadul
I am trying to perform a heat transfer analysis on a column consists of three layers. only the middle region is heated and the top and bottom region are the same as at the air temperature. the three layers were tied together and everything should be set right. However, when I perform the analysis I noticed that the temperature values at some regions, "particularly the boundaries when I have rapid change in temperature"are going below the air temperature even go down to negative then go up again. I used one layer only to detect where the error is, and it worked fine. then I used the all three layers with all column heated and it worked fin too. It sounds that I have this problem only with more than one part tied together and with the mid part heated only. Any idea what could cause this problem?
Manar
Manar
