knowlittle
Materials
2 metallic objects separated by vacuum.
Vacuum level 10e-6 torr.
HOT 120 C, COOL 20 C.
Distance 8 mm (1/3").
Surface areas same (25 x 250 mm, 1"x10")
HOT 25 mm thick (1"), COOL 6 mm (1/4")
HOT electrical heating strips on 2 sides.
COOL water cooled copper line brazed on the back.
Temperature: measured with thermister from the back
Temperature control: 1 C OR BETTER.
When the back plate reads 20 C, how realistic is it for the front (facing 120 C object) not to exceed 21 C? Can someone do rough calculation for me? Both objects are aluminum with electroless nickel plating. Ignore edge effect. Thanks.
