gooutandgetem
I have a 16" wide by 22" deep heat pump fan coil unit (upflow). I want to intall in a closet with a 24" door. The closet is 36" wide and 26" deep.
My thougt is to place the units left edge at he left edge of the door, so the control panel can have clear access. The line set connections can be connected at the coil in the front and the power would be on the right side (leaving 8" between side power access hole and side wall).
Then I would just undercut the door and install a side return filter grille on the side of the unit.
What do you guys think, it is tight but doagble (I think).
