Heat Exchanger for N2
ETI4Mark
Aerospace
thread391-130156
Any design input for making a heat exchanger to regulate the discharge temperature of compressed nitrogen gas for flightline use (i.e. service struts & tires). HX to be sized so that discharge temperature is -60F or warmer with constant supply of nitrogen at flow rates up to 32 SCFM. Fan supplied with HX shall be driven by a motor that operates from compressed nitrogen as well.
I'm assuming that you are a new member, so welcome. Note that the cited thread is 8 years old.
you may wish to change the display order of threads to "by date" in "My Profile"
TTFN
faq731-376
7ofakss
Al is commonly used for pure gas HX applications.
If your pressures are too high for reasonable wall thickness then move to SS.
Plymouth Tube
