HCL and 17-4 SS- any good?
jackboot
Questions:
Would 17-4 (double aged H1150-NACE certified) be a suitable material in 7.5% HCL? Or would it be better than 4140 (NACE)in the same environment?
For the same solution - would Aluminum-Nickel-Bronze be better than ductile cast iron (80-55-06)?
Thanks,
jackboot
4140 will dissolve faster than 17-4PH. Neither is suitable.
The others aren't any better. If you're going to use an alloy, it should be nickel based.
thanks for the info.
jackboot
