One of my current projects has the contractor welding 3/4" dia headed studs to an existing plate. The existing plate is HDG. I need the coating ground off prior to welding the stud. How far beyond the stud surface should the zinc be removed. I've usually used 1/2", but am thinking this may be inadequate. The fillet weld is 5/16.
