Hatch pattern
  • Thread starter Thread starter Aimon
  • Start date Start date
A
Aimon
Guest
Can any one help me by explaining how to extend a hatch to a new boundary? I am aware to trim the hatch pattern to a new boundary but can we extend it.
Thanks in advance.
Hi Aimon,
You can use grip editing to stretch the boundary and the hatch, and it should be associative, will adjust to fill the new area of the boundary. Please note that, you have to move at least two connected lines from a common endpoint if your boundary is LINE objects.
Or from the point you want to extend select the option for "point" or "object" selection and the hatch will move to fill the new boundary object. It will use the currently selected "island detection" mode so it may be removed from the original boundary if the new one is completely surrounding it. If this happens just delete the original boundary or change the island detection mode.
