69thbugler
I have been working on the problem of automatic hexahedral meshing for the best of my engineering career, searching for the elusive “Holy Grail” of engineering analysis. After studying the behaviour of quadrilateral meshes in 2D and hexahedral meshes in 3D for years, I have identified a pattern that is found in all such meshes, the presence of irregular nodes, nodes where three or five elements meet. The pattern has been mathematized, and a simple, elegant solution emerges. I can at last say with confidence that I have solved the problem of automatic hexahedral meshing, a solution that is very different from any of the other approaches to solving the problem.
The findings can be used to manually create better quadrilateral and hexahedral meshes in existing FEA pre-processors, and a software implementation will make it possible to speed up the manual hexahedral meshing process by a factor of 10. Eventually, the process can be automated, but that is years away. I have now the challenge of finding financial backing to develop the algorithms for inclusion in or interfacing to existing FEA pre-processors.
However, tetrahedral elements have been successfully used for many years, and the work on creating meshable volumes for hexahedral meshing replaced by automatic tetrahedral meshing algorithms. Several vendors have launched the ultimate hexahedral meshing algorithm, but testing in the engineering community has left them wanting. The ultimate hexahedral meshing algorithm is still elusive. Engineers have stopped asking for it, because it is not available in the shops.
I am looking for advice from the structural engineering community on what I should do, forget the whole thing and get on with the rest of my life, or spend more time and money to develop a solution for automatic hexahedral meshing?
What are the application areas where hexahedral meshing will be highly desirable? Where can hexahedral meshing complement the tetrahedral meshing technology that is used successfully today?
What is the commercial opportunity for hexahedral meshing, the applications, the problems to solve, the end-users and vendors that want this, i.e., the substantial incentive necessary to invest in the development of this technology?
