This is related to my other thread about changing the rated voltage of a VFD motor.
I have some basic questions about VFD outputs.
1. Does the output voltage of VFD below the rated voltage have more harmonics as compared to the rated voltage ? i.e. If the rated output voltage is 440 V, does operating the VFD at 220 V produce more harmonics ?
2. Do the harmonics of the VFD output change with the frequency ? For example, does a 25 hz output have more harmonics as compared to a 50 hz one ?
3. Do all VFD's have a parameter to take care of V/f issue ? For example, if a 380V, 60 hz motor is operated at 50 hz, how does the VFD take care of the V/f issue ?
