Is/was the harmonic drive a descendant of Fergusons idea?
Harmonic drive>
Skip to 6.50 in the video below for what I think is Fergusons doing, but Im not sure if Ferguson ever had an outer gear ring in his plans. But, looking at the drawing below, gears f + h could be the outer rings but just in a different form.
Video,
Original plans/idea
Both the above are 'similar', in that they use 1 or more teeth less for operation.
Could the harmonic drive invention have been a copy of Ferguson's idea?
Another example of Fergusons idea
The reason I ask all this is because Im currently designing a servo powered 4th rotary axis for a cnc machine table and Im getting confused as to where one design starts, and the other stops.
Granted, the harmonic drive due to its design is '0' backlash, but with Fergusons example in the last video posted above, you could fit heavy springs between both gears similar to a scissor gear?
With that In mind, Im thinking torque losses would be similar for both designs, since the harmonic drive 'basket' has to deform while rotated.
Harmonic drives fetch around 3keuro which is why I ask all this.
Perhaps I should just scrap all my thinking, and go with a worm.
That has its downfalls too though.
Interesting stuff for sure,
Thanks in advance for any pointers,
Brian,
Harmonic drive>
Video,
Original plans/idea
Brian,
