We have a cut-off saw that has SS socket bolts with carbon steel t-nuts for the clamps and hold downs. The nuts are seizing due to the coolant. We replaced the bolts and nuts and added corrosion inhibitors to the coolant but my questions are, should we switch to SS nuts or will galling be a problem? Also, does Cu or Ni based anti-seize help this or help with the seizing of the carbon steel nuts? I'm a recent grad and haven't had any experience with this so I'm looking for some help. Thanks.
