HAP: basement wall input
wufi2004
42
How to define basement walls in HAP(Hourly Analysis Program)?
I know how to input data for space above ground, but how to do it for basement walls?
Basement walls are defined just like a wall next to an un-heated space. Define the thermal properties and the temperature differential. Since most ground temperatures are around 50 F. use this as the temp for the un-heated space.
Thank you!
But i will use winter heating in the basement. Then how to do it?
Can i define basement floor ? I found this. But i need to know which slab is slab-on-grade, which slab is slab-below-grade. How to differentiate them?
To define the basement walls you have to use slab below grade. When you do that more options will be shown for both floor and wall r-values. The basement wall construction is not as detailed as the typical wall construction that you would input into the library section in the program.
See Carrier Handbook of Air Conditioning System Design, Chapter 5, Page 1-81.
My basement wall is like this:
_______________________________________ Ground Level
| Basement 1 |
|________________| <---- What is this slab floor called?
| Basement 2 |
|________________| <---- This is slab-on-grade or -below-?
Besides, I'm trying to find the Carrier Handbook. Thanks!
Please give me more hint.
Using HAP i would deal with your scenario in the following manner.
Basement 1 - shares a common floor / ceiling with Basement 2 and common floor / ceiling with Ground level.
I would treat Basement 1 floor and ceilings as partions, in fact i would treat all walls this way too, just choosing for floor tab (above conditioned space).
Basement 2 - shares a common floor / ceilgin with Basement 1 but has a slab below grade.
I would treat all the walls and the ceiling to basement 2 as partitions and enter the slab below grade details for this level into the floor tab.
One way of dealing with your dilemma..
