NeilL286
- Jun 24, 2013
- 15
My co designers at office just determine if the girder portion where beam frames into it has sufficient V to resist the shear of the beam. They assume the reaction from the floor beam is more or less uniformly distributed through the depth of the interface between beam and girder. But in references, there is this compression strut forming from beam to lower part of girder which has to be provided for by means of hangers stirrups inside the joint that serve as tension ties to transmit the reaction of the beam to the compression zone of the girder, where it can be equilibrated by diagonal compression struts in the girder. And so these hanger stirrups are supposed to be put inside the joint itself (see illustration provided). Do you put them too, as not all follow it?
