NACE MR-0175 also has a chart of to determine if SSC is going to be a problem/concern.
From memory, if under 750 ppm, it is based on partial pressure. If over 750 ppm, it is based on total pressure.
You should go through the NACE MR-01-75 document.
"Do not worry about your problems with mathematics, I assure you mine are far greater."
Albert Einstein
Have you read FAQ731-376 to make the best use of Eng-Tips Forums?
