joaex
- Jan 14, 2015
- 1
Hi, EIT here. My interests in college were mostly focused on steel design, and unfortunately I'm not in that line of work now, but I try to keep learning more about it so I'll be better-equipped when it comes time to move on. I often try to look at how things are put together "in the wild" to get a better idea of general practices and a better handle on nuances of design. One thing I've seen a few times that has me a little confused is guardrail connections striking me as a little underdesigned. I've read that C and MC sections have very little torsional strength/stiffness. But I've seen guardrail sections (on stairs especially) that connect the posts to the channel stringer with two bolts through the flange, oriented longitudinally, or to a small clip (4 or 5 inches in height, say) in the center of the beam web. Using the design LL as a 200 lb point load applied at the top of rail, it strikes me that, say, 1.6*200lb*4ft=1.28k*ft is a lot of torsion to apply to these sections. The "two bolts through the flange" approach sometimes looks like it can't have a resisting moment arm of much greater than half an inch or so, which would mean almost 31k of uplift, and the "clip on the web" approach on a flimsy web just gives me the impression that it would deform a lot, locally. And either way, the channel section itself eventually has to deal with the torque, and I haven't tracked down a design procedure to give me the torsional stress/deflection for a C-shape (which I gather is complex) but treating the section as rectangular but making some educated-guess equivalent rectangular sections gives me the impression that the sections are borderline at best in handling it. And that's to say nothing of torsional deflection, and over a stair stringer with 12' of rise, say, I imagine the deflection (assuming the treads don't somehow restrain it) would be large.
Anyway, I've been lurking here and thought I'd ask this, because it's been nagging at me for a little while. It seems to me that the lateral live-load from guardrails should very much be a controlling factor in elevated platform/stair design, but I don't really see it talked about explicitly all that much. Is there a reason for that? Or am I way off here?
