I said what I said based on the picture shown for the groove prep for a lap, with nothing running down the side. The PJP groove weld is no worse than a fillet weld in the same situation--same susceptibility to prying apart at the root.
The difference between a PJP groove weld and a fillet weld can get a little subtle--and a little irrelevant, if I may say so.
However, a strict reading of the bridge code puts more restrictions on the PJP groove weld than on the fillet weld. 2.6 says "PJP groove welds shall not be used where the applied tensile stress is normal to the effective throat of the weld."
Section 2.10 has a lot to say about lap joints in general. They keep talking about fillets and never about PJP but the only difference between one and the other is the bevel prep. In a way, a PJP groove weld can be considered a fillet in a groove. Others will now jump all over me about how they're TOTALLY DIFFERENT AND HOW DARE YOU SAY OTHERWISE.
If it were my call, though, I wouldn't have a problem with beveling back the lapping member to get more weld in there, thus technically making it a groove rather than a fillet weld.
Okay, off to ask AWS about why PJPs would be barred where fillets are allowed...
Hg
Eng-Tips policies: faq731-376
