I've a spreadsheet for plotting pump curves on one chart but the problem is in adding the abscissa (x, flow) values for the same ordinate (y, head) values. The two curves are not input with common y-values. The fastest way seems to be to plot out the two pump curves on one chart then create the combined curve manually by hand with a ruler. Presentation isn't the best. Pump supplier software is geared for their pumps alone and I want to be able to superimpose a couple different mfgr's pump curves on my system curves. Any ideas?
