EngJW
- Feb 25, 2003
- 682
In case anyone is interested, it looks like it can be done. As other posts have pointed out, it will install but you can't start it. However, you can check it as "run by administrator" and "XP compatible" mode. I can't tell you how I did this because it took a number of attempts to find the right menus to make the changes. Basically, it is by right clicking one of the icons and selecting properties. So far I've had it running all weekend without a problem. You just have to acknowledge the Vista silly warning when starting it.
SW 2006 was installed on the same machine with SW2008 but I haven't seen any interference yet (although 2008 is not useable now because the license was transferred to another computer).
