Hitokiri03
I am designing a crude glovebox and I am trying to figure out how to make calculations for the air change. Are there standards for what the air change should be?
Here is the situation:
Our area is currently pour 1 gallon of powered acid into a mixing tank filled with water. In order to prevent powered acid particulates from getting on the employee, I am designing a glovebox to go on top of the tank opening. I have a port for our HEPA vacuum (87 cfm) hose to attach to the glovebox and another port to allow for ambient air to crossflow into the glovebox during suction. I am trying to calculate when the air would be safe inside the glovebox. The employee would pour the acid into the tank, remove their hands from the gloves, open the ambient air port, and turn on the vacuum at the vacuum port.
