MarineGreg
Marine/Ocean
- Dec 22, 2006
- 12
I am wanting to use globe valves for throttling flow in a marine cooling system application instead of an orifice.
But once I adjust the globe valve to the proper position, I want to ensure it can be repositioned to this same height if it gets mistakenly turned. Or a lock to prevent rotation would be good.
Is there a globe valve out there with a lock or a scale on the stem that shows it's position?
Thanks.
Thanks.
