glitch
schoryan
Automotive
the only thing that still gets me that they havent fixed in ug is the prefernces should be made like the tool bars so you can save your settings. in the preferences/object menu
you cant save what color you want your solids to show up or datums or lins or sheets
you have to do it for every file you start
which sucks when you have std colors for solids, and other entities. unless you guys have figured out a way to save them. im on a hp unix box
designer gooroo
catia v5
unigraphics nx
pro-e wildfire
ideas v10
autocad 2004
These settings are in the ug_metric.def and ug_english.def files.
Ben Loosli
CAD/CAM System Analyst
Ingersoll-Rand
yeah but how do i modify those files?
to i have to open them with notepad and manually edit them?
designer gooroo
catia v5
unigraphics nx
pro-e wildfire
ideas v10
autocad 2004
Yes. Administrator priviledges are usually required. It is a good idea to save a copy before editing (for backup).
From what I've heard (from reliable sources at UGS) is that starting with NX3, there is going to be an interface within UG that sets these defaults & saves them upon exiting & restarting UG....so, we won't always be having to edit .env & .def files.
Also, if you're using the GM Toolkit, you'll have to modify the metric.def file that is in the Toolkit config directory, NOT the metric.def file that is in the UGII directory.
Tim Flater
Senior Designer
Enkei America, Inc.
