I am planning on installing a power distribution system to provide 80 vac for heating inside vacuum chambers. 80 vac is the accepted limit to prevent the occurence of corona which occurs violently with higher voltages as the absolute pressure is being decreased. These chambers may be "inhabited" by a human being (astronaut) for testing purposes. So, I need to provide GFI protection for all the circuits.
The various available units that are sold commercially seem to only be rated for use down to 102 v (120 v -15%).
I am sure I could design a GFI which uses a separate control circuit to sense the output of the current transformer etc. but this would surely be expensive. Obviously it would also lack industry approvals.
So where can I find an approved GFI for my needs?
