get user input 1
Zoes
GB
Code:
Dim initial As String = "enter name"
Public Sub dialogShown_cb()
Try
string0.GetProperties.SetString("Value", initial)
string01.GetProperties.SetString("Value", "")
End Try
End Sub
Public Function apply_cb() As Integer
Try
Dim UserInputString As String
UserInputString = string0.GetProperties.GetString(initial)
string01.GetProperties.SetString("Value", UserInputString)
End Try
End Function
Error: Invalid property name for the block... .GetString(String propertyName)at appy_cb()...
Anybody knows what's wrong with the above code? I'm guessing is something simple but I can't see what it is!
Instead of in the apply_cb function use the update_cb function which needs to be
Public Function update_cb(ByVal block As NXOpen.BlockStyler.UIBlock) As Integer
Try
If block Is string0 Then
UserInputString = string0.GetProperties.GetString("Value")
string0.GetProperties.SetString("Value", "Enter Name")
ElseIf block Is string01 Then
'---- Enter your code here -----
End If
Catch ex As Exception
End Try
update_cb = 0
End Function
Hope this helps
Frank Swinkels
Thank you!
Can I further ask if you know the attribute for making the string visible/hidden?
I was looking to find the state of the string and change it.. but nothing similar appears in the library.
There is a show method which for say string0 is
string01.GetProperties.SetLogical("Show", False)
This would hide all string01. Simply use
string01.GetProperties.SetLogical("Show", True)
to again show it.
Is this what you were looking for?
Frank Swinkels
