geometric tolerance symbols
  • Thread starter Thread starter saspinall
  • Start date Start date
S
saspinall
Guest
There are some geometric tolerance symbols which do not appear in the symbols box when inputting gtols. ie taper is the one we wish to use. Anyone know whether they can be added as symbols to the palette or if they can be added some other way. Thing is if I add as a symbold then won't be able to get box around or use any references etc.
Stu
do this by enclosing notes in boxes.
example: @['Conical_Taper'@]@[0.01@]@[A@] ***'Conical_Taper' symbol is shown in the Symbol Palette.
if you want to make this as a symbol instance just input backslashes for the texts to be variable.
example: @[\'conical staper'\@]@[\0.01@\]@[\A@\]
or start a new note then hit ctrl+a then type till you find your symbol ctrl+b to exit
