bdf5526
- Nov 26, 2007
- 51
Hi guys,
We have a problem with the generator line current unbalanced at +6MW output and -2MWar.
Measured current at 14.5 kv (Gen Nom. Voltage); L1 = 216 A
L2 = 364 A
L3 = 286 Max and min current difference is about 150A. I am not sure if this is normal.
Clients are chasing us since the plant trip (two times when reacing 20 MW) on GSU Trafo differencial protection. The type of reley we are using here is the areva P633. I have inserted the print shot from the relay the one i got from my friend.
When I measured the current at the HV side of UAT Trafo the current are balanced. I measured unbalance current at the HV side of the step up trafo (225kv). Is it possible the grid could draw unbalance curred for what ever reason?
Thanks in advance guys.
L2 = 364 A
