Is a Thermal Generator. It uses air for cooling and have 4 radiators underneath the generator where water circulates. For check the stator winding temperature, we have 12 RTD. 4 for each fase.(total 12). There are 4 damage, because the measure of the resistance in this devices are infinite. They are located in the slots someone under the stator windng.
Additional to this RTD, we also have the Stator teeht temperature (2 lectures), Stator Core temperature (4 lectures), and the temperature of the air inlet/outlet for coolinf for each side (Non driven, driven side).
The problem is that the generator could lost more RTD signal, and we won`t know the temperature of the winding. In case of a temp increase, how to avoid any problem. We used to down the reactive load, but in a dangerous case, we would down the active power.
Also i did a thermal scan, but it isn`t continue like the RTD. I want to know if exist alternatives like a formula to calculate a avg temp for a given load of the generator.
Thanks for ur help
