Hi, our Main Generator (132 Mw - Ercole Mareli 13.8 Kv) has a problem in the brushes. The collector ring has 11 brush per side. (positive and negative). We had a high desbalance with each current´s brush that causes overheating and damage. recently we buy new brushes (Alstom - OEM Generator) but our problem persist. We check the spring pression and it ok. Some brushes doesn´t carry excitation current and the other take it, making a high current difference. Some people say that could be the AVR the problem source. (Harmonics). If you know something to do or check, give me a hand.
