G
geforce4us
Guest
I have a question about my system that has graphics problems with a GeForce Ti4400 (128 megs of RAM) running on as system with an Athlon XP 2000+ processor and with 526 megs of RAM. The OS is WinXP Home (too cheap to buy Pro). Two bugs are slight annoyances, one makes ProE very difficult to use.
When I rotate a part, the rotation is smooth, but little black boxes pop up in the window, kinda like static. Also, I can't used crtl+D or crtl+A to go to default view or activate a window. I don't use any other keyboard short cuts, so I don't know if they work or not, but I have no problem using crtl to pan, spin, or zoom.
The major problem comes in scetcher mode. The lines all show up without a problem until I try to draw more lines, circles, points, arcs, etc. Then they dissapear on me. When I click on the pointer or go to create constraints/dimensions, then all the lines show up just fine again. This makes drawing a very tedious process because I'm never sure of what I'm drawing until I finish.
Any help?
P.S. I was opening some other files made by other people and for a while, all the bugs disappeared, but came back when I opened parts I made. Could it be a problem with the config file?
Any help?
