malegault
- Feb 8, 2011
- 5
we have two metal gears that needs to be mounted with a high level of coaxiality on a machine (~0.0001 or less). To do so we are developping an assembly jig with a shaft that will be machined with the coaxiality requirement need. This shaft will be used as a guide to align the two gears before being fixed.
Do you have any suggestions regarding the steel we should use for the fabrication of this alignment shaft?
Tony
Tony
