If datum D is the bottom or top surface of the connector and datum E is the OD (left to right), I don't think there is anything wrong with this in terms of how the features are dimensioned and toleranced but attaching the FCF to the extension line is not right and having the FCF cross over them is not right either as ringster said, but I don't think you were asking for a critique of your drafting technique. You were asking whether or not your dimensioning and tolerancing scheme was sound. In the absence of the rest of the drawing and making a few assumptions, I believe it is. There is nothing inherently wrong with having your positional tolerance looser than the feature tolerance unless it renders the part non-functional, but the practice itself is perfectly GD&T legal.
Evan,
I have a question; you mentioned the 6.40 dimension as being a classic example of a plus/minus tolerance on a "non feature of size" as if it were wrong to do. Is this what you meant or am I reading too much into your comment?
Powerhound, GDTP T-0419
Production Manager
Inventor 2009
Mastercam X3
Smartcam 11.1
SSG, U.S. Army
Taji, Iraq OIF II
