I will install the machine which is working pressure is about 20 bars, then I have a problem with leakage due to the alighment of pipe was not alight properly, but when I change to PTFE gasket with 6 mm. the leak was stop. So, is it possible or not to use 6 mm. PTFE gasket with 20 bars in pipe.
