Interesting, and maybe I am wrong (others?) but on speculation:
1. A watch sealing protecting from outside to inside against water pressure could be either for back lid, front cover or time adjustment screw. The last the most difficult, possibly both for rotary and axial movement.
(Alternatively: all pushbuttons digital and 'put into a rubber sack' : contact pressure: zero!)
2. Thightness would depend on several factors:
a) geometrical form (length of sealing area, whether outside pressure would contribute to extra pressure by acting on larger area than inside and elasticity in sealing giving larger contact pressure for sealing (against stem)
b) Precision of sealing and stem measurements (roughness, form and clearing/fitting between the two components)
3. Thightness to be dropthight (no leakage at all), that is no water molecules able to pass.
Result:
c) Contact pressure must be sufficiantly higer than outside pressure minus inside pressure to compensate for outside variations (caused by practical use, movements and variations in water density) and inside variations (possible compression of air inside watch caused by compression of total watchcase by outside pressure).
d) Or contact pressure might possibly(?) be lower if fitting is so thight that contact area 'spillroom' under all outside/inside practical possible pressure conditions are smaller than a water molecule.
